92 gsr tranny
Re: (AMeg6)
There's lots of aftermarket ones if your interested. You could get one from Honda, but itll probably run more than the aftermarket ones, unless that is if you know someone in the parts dept.
Re: 92 gsr tranny (Davep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davep »</TD></TR><TR><TD CLASS="quote">You can use an ITR/CTR LSD in the 92-93 cable transmissions too.</TD></TR></TABLE>
if you wanted to do this you would have to shave the casing just to make the lsd fit right
if you'd like to use a LSD that fits right in without any modifications you can use an LSD from a JDM 92-95 hydro B16A tranny [good luck finding one tho!]. 92-95 hydro B16A + 92-93 B17A cable tranny's share the same internals [gearing + diff].
92integraVTECgsr
11-29-2005 02:06 PM
