automatic h22 ??
Old Dec 12, 2003 | 06:14 AM
SAVIOVEGA's Avatar
Default automatic h22 ??
Is there a difference between the H22 engine that came with manual and automatic tranny ?
Old Dec 12, 2003 | 06:50 AM
v4lu3s's Avatar
RTFM
the longblock is the same for auto or manual with the jdm engines.
Old Dec 12, 2003 | 02:16 PM
AMeg6's Avatar
the h22a originally equiped with an automatic has less HP than a original manual engine
Old Dec 12, 2003 | 03:13 PM
SAVIOVEGA's Avatar
Default Re: (AMeg6)
Can you tell the difference just by looking at the engine ? Intake manifold ??
Old Dec 12, 2003 | 04:45 PM
Maintenance's Avatar
Default Re: (SAVIOVEGA)
i'm not sure but the engine horsepower rating should be the same. And the only reason people think its less horsepower with an auto is because you loose more horsepower thru the auto tranny with a torque converter. regardless if the engine is auto or manual it should be the same horsepower, its with the tranny you are using. if i'm wrong somebody please correct me on this
Old Dec 12, 2003 | 06:06 PM
v4lu3s's Avatar
RTFM
an automatic jmd h22a is exactly the same engine as the manual.
Old Dec 13, 2003 | 05:34 PM
Newman's Avatar
New User
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">an automatic jmd h22a is exactly the same engine as the manual. </TD></TR></TABLE>
Correct. We've torn them down before, and the pistons, manifolds, and the cams are the same. Everything else (assumed, since there isn't anything else to change for a power decrease) is the same and same part & numbers.
hany
12
Apr 21, 2007 12:43 AM
jdmh22a1
Apr 5, 2007 06:10 PM
djnikko
Jan 7, 2006 09:45 PM
abeaujuin
Jul 24, 2004 05:27 AM
Mrfirefox
Jul 23, 2002 08:20 AM
