Just dropped motor in and will not idle
I just put a 96 b18 ls in a 93 cx car starts/runs great it just wont idle. the car is giving me a code #1 O2 sensor but i dont think thats the problem. i checked for any possible vacuum leaks and cant find any,tried unplugging the iacv and it lets it drop a little set screw in T/B turned all the way in.
The 02 sensor is a four wire and i checked all the wires and they are ok is there a way to get a new/newer one w/out paying $200.00
Re: Just dropped motor in and will not idle (joecivic93)
take your IACV off and spray it out with carb cleaner, sometimes the valve sticks after sitting for a while.
and check autozone for an o2 sensor, it shouldnt be that much...
Re: Just dropped motor in and will not idle (Kamin)
Thanks i will give it a try!
the 02 sensor is $150.oo for a universal and $200.00 for a oem from autozone i will look around and see what they are going for elsewhere!
get a universal that will thread into the bung on your header, one with a plug already attached will cost alot more. just a universal type you have to cut and solder the wires, but it is 50% cheaper.
GTEC913
07-01-2008 02:11 AM
