Another B series swap problem
Well, I'm putting this turbo B16 into my 91 Civic Hatch STD with HCP mounts. Unfortunately I'm having the worst time getting the rear mount to line up properly. I just wanted to see if anyone has had a similar experience and if they knew a possible solution to the problem. Any insight is much appreciated.
Re: Another B series swap problem (moridin2004)
Which rear mount bracket are you using? The proper one should be a 90-93 Integra rear bracket. Also the rear mount should be moved toward the passenger side on the other set of nearby bolt holes.
91BlueEF9
09-08-2007 07:00 AM
ExodusJKD
03-25-2005 10:16 AM
