o2 sensor question
Old Dec 18, 2003 | 06:31 AM
mrchris386's Avatar
Default o2 sensor question
I just got a 98 jdm b18c swap into my 95 civic and the engine light is on. Hooked it up to the computer and it says its because of the o2sensor....So i have to get a new o2sensor and was wondering if i could use the o2 sensor from my old DX motor? If anyone knows anything about this please post! Thanks!
Old Dec 18, 2003 | 08:42 AM
Devlins 91LS's Avatar
Default Re: o2 sensor question (mrchris386)
No. Your civic was obd1 correct? and the c1 is obd2
you COULD convert it...i guess...
Check wiring before you replace it, cuz that ****'s expensive.
Old Dec 23, 2003 | 08:14 PM
IDriveHonda's Avatar
Default Re: o2 sensor question (Devlins 91LS)
They are both 4 wire arent' they?
Old Dec 24, 2003 | 03:51 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchris386 &raquo;</TD></TR><TR><TD CLASS="quote">I just got a 98 jdm b18c swap into my 95 civic and the engine light is on. Hooked it up to the computer and it says its because of the o2sensor....So i have to get a new o2sensor and was wondering if i could use the o2 sensor from my old DX motor? If anyone knows anything about this please post! Thanks!</TD></TR></TABLE>
As long as it's a 4 wire O2 sensor which it should be, you can reuse it no problem. The OBD of an O2 sensor doesn't matter, primary + secondary doesn't even matter (when talking about OBD2), as long as it's a 4 wire then you're good.
egg_baLLa
Feb 3, 2006 12:29 PM
XzzYzzX
Jun 12, 2005 09:52 AM
boomnn
Mar 27, 2003 02:58 PM
zerofighter777
Feb 13, 2002 10:12 AM
