H22 swap into a 97 Accord
Re: H22 swap into a 97 Accord (Redek4)
harness- use accord harness... you have to cut and lengthen some wires... also add a knock sensor wire... and vtec wires if you dont already have it
ecu- use h22 ecu
axles- both accord and prelude axles will fit
if you have anymore questions just use the search button... your questions have been asked before... dont forget to click archivevd post
ecu- use h22 ecu
http://importnut.net/h22a_swap.htm check this out. It should be able answer you questions.
