exhaust/header/cat
Old Dec 18, 2003 | 06:49 PM
Hybrid2Be's Avatar
Default exhaust/header/cat
i'm swapping a gsr motor into a 4 door 93 civic.. what exhaust/header/cat combination will fit? like.. can i use the gsr header with the civic cat/exhaust? do i have to fabricate? thanks ahead of time
Old Dec 18, 2003 | 07:33 PM
VTECVillain's Avatar
Default Re: exhaust/header/cat (Hybrid2Be)
The GSR header is about 4" shorter than other B series which creates a gap between it and your cat/exhaust flange. If you order a cat-back exhaust system you will need to order it for your chassis, same for the cat although most are universal. For the header, if you get an ITR/Si header then it will be the proper length and meet up with the exhaust/cat. Otherwise, using the GSR header you will need a custom piece to fill in or added onto the exhaust/cat to fill the gap.
Beau Gotti
Jan 15, 2008 12:36 PM
jonnybadboi9
May 1, 2007 05:56 PM
Broken Devil
Oct 3, 2005 09:55 PM
overboostedcivic
Jun 13, 2004 06:05 AM
BlackAC99
Nov 14, 2002 09:00 AM
