b18b in an ek. bogging
Old Dec 24, 2003 | 03:20 PM
redds's Avatar
Default b18b in an ek. bogging
we just put a 99 b18b in my friends 96 dx hatch. we got it running and warmed it up on the stock dx ecu. it idled fine but when you gave it gas it surged. we figured it could have been the ecu so we put the teg one in and it did the same thing plus it wouldnt idle on its own. right now its on open header because its a little late to go to an exhaust shop. anyway if anyone can help with this it would be great. i tried searching but didnt find much. thanks in advance.
Old Dec 24, 2003 | 05:06 PM
VTECVillain's Avatar
Default Re: b18b in an ek. bogging (Redds)
Is it throwing any CEL's?
Old Dec 24, 2003 | 05:13 PM
redds's Avatar
Default Re: b18b in an ek. bogging (VTECVillain)
we figured it out we had to repin for the iacv on the ls ecu. not the only thing is that when you give it gas and let off it backfires a little. i have my friend bringing over a timing light now. what should degree should it be set at?
Old Dec 25, 2003 | 05:05 PM
kinvid22's Avatar
if you're running obd2, you need both primary and secondary 02 to function WITH a catalytic converter on...my b20 was bogging until i put a cat on, it stopped.
ej15012
Jan 31, 2010 10:56 AM
lowexr
14
Apr 10, 2005 03:03 PM
doublethink
Apr 3, 2005 01:58 PM
slo95cx
Feb 19, 2003 06:56 PM
