Anyone help me with CEL-
Old Dec 19, 2003 | 07:57 PM
_jester_'s Avatar
Default Anyone help me with CEL-
I keep getting a CEL 9 and its driving me ******* crazy? I have taken this thing apart and reset the timing about 5 times now just to make sure everything is perfect-
I am using the same distributor and ecu that was in my eg- (its now in an ek). The only verying factor is the wiring harness which i have also checked, everything is good? Anyone know what could be up?
I have also ohmed out all sensors and they read good- I just can't figure this **** out?
Old Dec 19, 2003 | 08:19 PM
Maintenance's Avatar
Default Re: Anyone help me with CEL- (XratedSi)
a little more info. might help. What motor? into what car?
Old Dec 19, 2003 | 08:24 PM
_jester_'s Avatar
Default Re: Anyone help me with CEL- (racerxfear)
**** on me- Its a b16a2 (usdm 00'SI), was in my eg (Si hatch) now in an EK (dx hatch)-
Old Dec 19, 2003 | 08:25 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XratedSi &raquo;</TD></TR><TR><TD CLASS="quote">I keep getting a CEL 9 ... I am using the same distributor and ecu that was in my eg- (its now in an ek).</TD></TR></TABLE>
This is a typical CEL that relates with distributor bearing failure, a very common problem with older distributors, especially EG's. Do you have another distributor that you could change yours with? I can't say for sure because I don't know or haven't seen your setup. But check the shaft for excessive play and the wiring for any loose or bad connections.
Old Dec 19, 2003 | 08:36 PM
_jester_'s Avatar
Default Re: Anyone help me with CEL- (VTECVillain)
I worded that poorly-
I had my b16 in an eg, i kept the obdII dizzy and soldered on an obd1 plug.
I just got an EK and swapped everything over to it from the EG, soldered the obdII plug back on the dizzy and i am running the p28 with an obdIIa -&gt; obdI harness. I am getting two CEL's a 9 and a 42 (o2?) neither of which i am having luck finding
Old Dec 19, 2003 | 08:55 PM
There is no code 42, was that a typo? Did you mean Code 41? If so, Code 41 is the heater circuit for the O2 sensor. It sounds to me like in the process of reinstalling/rewiring something wasn't done right. Whether there is a bad connection or possibly something not hooked up at all, I would start troubleshooting from the sources: distributor and O2 and work your way back.
Old Dec 19, 2003 | 09:12 PM
_jester_'s Avatar
It was 41 sorry. I have double and triple checked- using continuity to verify i had the right wires and all- problem is probably something simple- I am going to try a friends dizzy, my shaft does have alot of pley in it-
This has been a pita- the EK was auto so the harness was a pain in the dick- ( iconverted it to 5-spd also.
Old Dec 21, 2003 | 10:29 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XratedSi &raquo;</TD></TR><TR><TD CLASS="quote">It was 41 sorry. I have double and triple checked- using continuity to verify i had the right wires and all- problem is probably something simple- I am going to try a friends dizzy, my shaft does have alot of pley in it-
This has been a pita- the EK was auto so the harness was a pain in the dick- ( iconverted it to 5-spd also.</TD></TR></TABLE>
hmm...code 41.
Perhaps you should trying running a new 02 sensor. That will probably fix this code.
code 9...
I suggest you try another distr. as VTECVillian suggested. Or double check to make sure you cam timing is right. If you're off a couple teeth you'll get a check light for cylinder 1 problems. But it sounds more distributor related, since you've soldered & unsoldered the distr. plug a couple times. Perhaps you resoldered a wire in the wrong pinout location, no?
Aaron Cayabyab
Jan 30, 2013 12:40 AM
alil2cul4u
Mar 31, 2012 11:40 AM
minime-civic
Jun 5, 2007 03:04 AM
EFin' Kyle
May 23, 2006 04:35 AM
WEldin4fun
Nov 9, 2004 02:59 PM
