stock harness not fitting help!!
I have been told so many times that you use the stock wiring harness while doing a swap with 99-00 civics. The distributor plug does not fit any sugestions?
Re: stock harness not fitting help!! (Jdm Ek Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm Ek Hatch »</TD></TR><TR><TD CLASS="quote">I have been told so many times that you use the stock wiring harness while doing a swap with 99-00 civics. The distributor plug does not fit any sugestions?</TD></TR></TABLE>
You must be using a distributor of a different OBD than the harness then. If that's the case, you will need to rewire the engine side harness plug or the distributor side plug with the proper matching plug.
Re: stock harness not fitting help!! (98jdmdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98jdmdc2 »</TD></TR><TR><TD CLASS="quote">let me guess the distributor has either one or two plugs? and the harness has the opposite of the distributor right? </TD></TR></TABLE>
correct, also the idle control vaulve has three wires and the harness only has two? whats that about. I'm am leaning towards that being my idle problem
vxnine
07-25-2005 05:49 PM
