mini-me in 91 hatch need rpm activated pill where to buy it at?
I have in my car a d16a6 bottom end with a 98 y8 head and a pm6 ecu i was wonderign where to buy an rpm activated pill for my car and where exactly does the pill go. Dont have the cash to buy a vafc and dont want to put vtec on flip switch.
Re: mini-me in 91 hatch need rpm activated pill where to buy it at? (wannab20hatch)
So I take it that you don't have the RPM switch yet either? I would get this from Summit:
Summit RPM Activated Switch
It's got adjustable RPM points, makes the perfect ghetto VTEC controller/actuator. You'll also need a 12V auto relay from Radio Shack which is only about $5. It will convert the negative 12V output from the RPM switch to a 12V+ output to activate the VTEC solenoid.
Re: mini-me in 91 hatch need rpm activated pill where to buy it at? (VTECVillain)
Thanks for the help. And all it will control is vtec correct wont mess with anything else? Have been reading tons about mini-me but just want to make sure before i order it or install it. Thanks again for the help.
I don't have the actual msd rpm pills for sale (uless i have a random one around here you may need, i'll throw it in) but i do have 2 msd rpm activated switches for sale if you need one, both set up for 4cyl cars...the pills you can get from summit for around $20. Here is my FS post https://honda-tech.com/zerothread?id=706173 let me know if you need one.
-Mike
-Mike
blkhatch92
11-29-2005 11:04 AM
kenjief8
12-27-2004 06:58 AM
CimorelliCRX
07-29-2002 11:12 AM
CLICC916
09-20-2001 11:06 PM
