obd2 d-series alternator on a obd1 b-series
anyone know how i would go about mating the two together?
i am swapping an obd1 lsvtec into an obd2 ek and i want to use the obd2 alternator from the ek. a local shop told me that i could either fabricate a custom bracket and mount the obd2 alternator to the lsvtec block, or i could somehow rewire the obd1 alternator from the lsvtec to accept the obd2 wiring harness. anyone have any suggestions? thanks.
Re: obd2 d-series alternator on a obd1 b-series (ID_ten_T)
The easiest thing to do is get the proper alternator which would be a B series OBD2 alternator. If you want to use the OBD1 alternator, all you need is an OBD0/OBD1 alternator plug then wire it in place of your OBD2 alternator plug. Don't try fooling with mounting a D series one, use the right parts and it'll make life a lot easier.
Re: obd2 d-series alternator on a obd1 b-series (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">If you want to use the OBD1 alternator, all you need is an OBD0/OBD1 alternator plug then wire it in place of your OBD2 alternator plug.</TD></TR></TABLE>
i think that i am gonna try to go this route. do you happen to have a wiring diagram of which wires from the obd2 harness will connect the wires from the obd1 alternator? thanks in advance.
hmtcrxsir
01-03-2010 05:53 AM
gezer
09-03-2004 05:17 PM
