White smoke problem
Old Dec 16, 2003 | 07:45 PM
EdBoon's Avatar
Default White smoke problem
Well today, I noticed that my engine oil level was very VERY low...and decided to change my oil. Then I noticed that I was low on coolant. So I also topped off the coolant in the radiator/reservoir.
So when I run the engine after I'm done...I notice white smoke/water from the tailpipe. Then it stopped smoking at idle, yet hitting vtec resulted in white smoke.
I will compression test tomorrow probably. If there is a blown headgasket....would the compression test show inconsistent numbers?
Would a complete flushing of the coolant system help?
Thanks.
Old Dec 16, 2003 | 08:12 PM
doublejz's Avatar
Default Re: White smoke problem (MikeJones)
was your coolant a milky color? like not a normal antifreeze color? If you take off your radiator cap and rev it looking at the rad does it bubble?
Old Dec 16, 2003 | 08:25 PM
EdBoon's Avatar
Default Re: White smoke problem (doublejz)
Coolant was not a milky color for sure.
I will try to rev and see if it bubbles. What is this gonna tell me?
Thanks for the help.
Old Dec 16, 2003 | 09:02 PM
doublejz's Avatar
if there are bubbles, then air is leaking from the cylinders around or through the headgasket into the coolant. don't rev it real high, just enough to see the coolant raise a little in the radiator. just rev it with the throttle body and watch. a compression test may or may not help you. Depending on how bad your head gasket is, it just might lower all the numbers across it'll help if you know what your compression was previously
Old Dec 17, 2003 | 07:31 AM
EdBoon's Avatar
Thanks again.
Old Dec 17, 2003 | 05:24 PM
EdBoon's Avatar
Well I revved it and noticed some bubbles.
My temp gauge seems to always be half way....yet my friend with a swap is usually 1/4 warm or just under the mid point on the temperature gauge.
The smoke isn't terribly bad...but I can kinda smell the "sweetness" of coolant.
To be honest, I've never done something major like take the head off to replace the headgasket...but I guess I really have no choice.
Mikey Hernandez
13
May 1, 2014 07:33 AM
larsbar
Jan 22, 2014 04:34 PM
xpdude
Apr 11, 2010 04:43 PM
Driven
11
Oct 29, 2004 11:41 AM
t616
Jun 21, 2003 02:35 PM
