B16a1 into EK?
Old Dec 14, 2003 | 09:53 AM
sleepyhamsterlx's Avatar
Default First gen B16a into EK?
Does anyone have one in their EK, cause HASport make a swap in kit for EK civics.
Old Dec 14, 2003 | 12:27 PM
Newman's Avatar
New User
Default Re: First gen B16a into EK? (Mgnlxsd)
By the time you get a hydro-cable conv kit, new rear bracket, new driver side bracket, new motor mounts, new linkage, change out the OBD-0 ECU, injecotors, and distributor to OBD-1 or 2 electronics (OBD-1 ECU, have to get an ECU jumper harness), and wire it all up to either OBD-1 or OBD-2, you would have probably spent just as much, and done more labor and running around piecing the swap together with the parts listed above, would have spent as much as a 99-00 Si B16A swap to begin with, where all of the mounts, brackets, linkage, and wiring (for the most part) is all plug & play and no running around trying to source little things here and there like a new distributor here or an ECU there. My $.02
But if you have your heart set on getting a 10 year old B16A1 swap, and want to go with that, then more power to you.
Old Dec 14, 2003 | 03:45 PM
VTECVillain's Avatar
Default Re: First gen B16a into EK? (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">By the time you get a hydro-cable conv kit, new rear bracket, new driver side bracket, new motor mounts, new linkage, change out the OBD-0 ECU, injecotors, and distributor to OBD-1 or 2 electronics (OBD-1 ECU, have to get an ECU jumper harness), and wire it all up to either OBD-1 or OBD-2, you would have probably spent just as much, and done more labor and running around piecing the swap together with the parts listed above, would have spent as much as a 99-00 Si B16A swap to begin with, where all of the mounts, brackets, linkage, and wiring (for the most part) is all plug & play and no running around trying to source little things here and there like a new distributor here or an ECU there. My $.02
But if you have your heart set on getting a 10 year old B16A1 swap, and want to go with that, then more power to you.</TD></TR></TABLE>
Thanks Newman, that about sums it up. A lot of people see that the swap is cheap but they don't realize all the extras it takes to make it work in a 92+ Civic. If you are installing it into an EF Civic/CRX (88-91) or DA Integra (90-93) then that's fine.
Old Dec 14, 2003 | 03:54 PM
Kamin's Avatar
Default Re: First gen B16a into EK? (VTECVillain)
booyah all the old school honda-techers are in agreement.
first gen b16's belong in 91 and older cars.
Old Jan 13, 2004 | 09:01 AM
likaciv's Avatar
Default Re: First gen B16a into EK? (Kamin)
I just bought a 91 civic sedan to get out of street racing, but the b16 swap is awfull tempting. What exactly goes into this swap as far as wiring goes? Thanks
NY GsR
Sep 25, 2007 02:37 PM
slowej1
10
Jun 13, 2007 05:13 PM
slow_SIvic
Apr 25, 2007 08:18 AM
silverh23ek
Jan 11, 2006 10:26 AM
danxdan
May 12, 2005 06:18 PM
