Question involving O2 sensor
Subscribe
Jun 1, 2004 | 10:24 AM
I have a 95' gsr engine swapped into my 95' ej. During the swap I had to make the wire for the O2 sensor longer. I have reason to believe that I might have crossed the two black wires going to the oxygen sensor. (2 black, 1 white, 1 green wires). Can anybody tell me if this is a problem? Any help would be greatly appreciated. Thanks.
Reply 0
Jun 1, 2004 | 12:17 PM
Re: Question involving O2 sensor (SpyderZEX)
If they touched and you turned the ignition 'on', then yeah, some damage could have occured. The fuse could have blown (Fuse 31, 15A, under-dash) or the ECU could have taken the hit.
Are you getting a Code 41?
What seems to be the problem?
Reply 0
Jun 2, 2004 | 09:41 AM
Re: Question involving O2 sensor (EE_Chris)
Yes... I am getting a code 41. However, I just started to get it. When I first installed the swap I was not getting any codes. However, I did just swap in a used O2 sensor that I pulled off of my old swap about a year ago. I was not getting any cells with the old O2 sensor, but I did notice some poor performance. I disconnected the old O2 sensor and found that the engine performed better. I figured that that sensor was dieing, so I pulled the sensor and put in the one that I had lying around. When I plugged the new one in, everthing appeared to be ok. After driving it for about 5-10minutes, I noticed that the cell light came on. Now everytime I start the car, there is no "check engine" light. Then, after about 5-10 mins., it comes on. This seems strange to me because I thought that the CE light would come on everytime you start the car until you reset the ECU. (pull the 7.5 amp fuse under the hood).
I know that this is difficult to follow at points, so if you can't understand it you can IM me or hit me up on AIM: SpyderZEX. Any help is greatly appreciated. Thanks
Reply 0
Jun 2, 2004 | 10:03 AM
The CEL should always come for 2 seconds when you turn the ignition 'on'. During this same time, the fuel pump will prime and quit when the CEL goes out.
After this 2 sec delay, if your ECU sees a 'hard' fault, the CEL will come on immediately....an example is a busted O2 heater element. I had CEL 65 (for the 2nd O2) pop up on me one day. It did turn out to be the sensor after verifying with a multi-meter.
Have you tried your old O2?
Have you tried another ECU?
Do you have Helms?
Do you have a multimeter?
Aside from just replacing stuff, you need a meter to do some resistance measurements as outlined in the Helms manual.
Reply 0
Jun 2, 2004 | 12:04 PM
have helms...
a multimeter....
tried old o2 sensor....
DO NOT have another ECU....
Reply 0
Subscribe
