Possible LS Vtec Setup
Old Jun 10, 2004 | 10:03 PM
jr01sr's Avatar
Default Possible LS Vtec Setup
What do you think about this possible setup??
92-95 hatchback ($1500.00-$3400.00)
95 B18B1 motor (Have)
B16A Tranny ($300.00-500.00)
GSR Main wiring Harness ($300.00)
Type R computer ($150.00-$250.00)
Type R head or B16A1 ($400.00-$715.00)
Jun type 3 intake camshafts ($528.00)
Jun type 3 exhaust camshafts ($528.00)
Skunk2 Intake manifold ($250.00)
Type R Throttle body ($185.00)
Type R Oil Pump ($115.00) or Spoon ($286.00)
Skunk 2 Cam Gears (Have them)
Type R Pistons And Rings ($400.00)
DC Sports Headers ($386.75)
AEM Fuel Rail ($139.96)
AEM Fuel Filter & Regulator ($176.49)
Type R Injectors ($250.00)
ACT clutch kit Stage 3 100% over stock ($507.87)
Skunk2 Titanium Retainers ($160.00)
Skunk2 Valve Springs
Toda Racing Lightweight Flywheel ($445.00)
Type R piston set ($350.00)
Type R rods ($150.00)
Any other possible mods??
All imputs are welcomed
Old Jun 11, 2004 | 01:49 AM
syndicate43's Avatar
Default Re: Possible LS Vtec Setup (jr01sr)
well first you should do what you want and not worry about what other people think.
second if you are going to use the typeR rods you might as well buy a type R motor.
From what I understand and I maybe wrong the point of using an ls block and rods is for the more displacement and the low end torque that the other b-series dont have if Im mistaken someone please correct me
Thanks
Old Jun 15, 2004 | 08:57 PM
jr01sr's Avatar
Default Re: Possible LS Vtec Setup (syndicate43)
Well what is up with th LSVTEC is that it has a bad R/S setup in other words rod and stroke ratio so what u need to do is get some Vtec rods and pistons so it will be reduced also u need to machi9ne them so your motor will be more reliable. But thanks for the feedback
Old Jun 21, 2004 | 08:59 AM
the ls stroke gives it a bit more displacement then the gsr or typeR I belive that is why it has the better low end torque
92SikHatchBak
May 1, 2009 07:57 PM
JDM-TypeRteg
Oct 6, 2005 12:40 PM
JDM-TypeRteg
Jul 2, 2005 03:40 PM
JDM-TypeRteg
Apr 14, 2005 06:46 PM
JDM_Risa
Jun 3, 2003 02:25 AM
