!!!!!!tach jumps around when driving, help with the problem
ok, i was in my friends si, and when he gives his car, his tach will kinda jump a little, like it doesn;t go smoothly from 5 to 8 rpm's- its jumps bad. like it jumps only under power, what could be wrong? is this bad? The clutch if fine, so ite not the clutch slipping, im not sure what else it could be. He hopes its not his motor.
Re: (vx_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx »</TD></TR><TR><TD CLASS="quote">its the igniter in the distributor.. going bad.</TD></TR></TABLE>
It cant be this, because its a brand new igniter from a honda dealer. Im wondering if it electrical. He just washed everything under the hood, so maybe its the water and stuff screwing things up. But i hope it not the igniter, he just bought a new igniter( as did I), he paid like $180 for it. so it shouldn't be that.
Crazy Honda Guy
Sounds like your ignitor to me too. Since its new, really cheak to make sure the conections are really tight with those little clips from it. I had a loose wire once when i replaced one, my car would just die every once in a while. It was an easy fix by tightening the crimp connectors.
Re: (Deetz)
ok, i told him that, he is going to try that. he was wondering any other possible causes, so he can look at every aspect of the problem. Thanx for the input though.
Maxcapacity
17
03-11-2008 10:53 PM
MtnCRX
01-11-2006 10:51 AM
