My first swap questions...
This is my first swap i am about to atempt.
My car is a 96 dx hatchback, and the engine i am purchasing is a b16a2 out of a 92-95 SiR and the swap includes the following :
»Motor
»Stock Motor Mounts
»5-Speed Transmission (LSD +$150)
»ECU
»Complete Engine Wiring Harness
»Civic SiR Axles
»Shiftlinkage
»Distributor
»Intake Manifold
»Alternator
»A/C Power Steering Pump
»All Working Sensors
what is this bout the radiator hose from a delsol vtec ?
also would i have to buy a whole new wiring to convert anything; if i am converting a obd1 engine into a obd2 car, with... uhh. i just don't get it..
i am stuck here, would i need new wires or not what else am i missing ? please help.
»Motor
»Stock Motor Mounts
»ECU
»Civic SiR Axles
»Shiftlinkage
»Distributor
»Intake Manifold
»Alternator
* B A N N E D *
Re: My first swap questions... (visionism0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by visionism0 »</TD></TR><TR><TD CLASS="quote">This is my first swap i am about to atempt.
»Motor
»Stock Motor Mounts
»ECU
»Civic SiR Axles
»Shiftlinkage
»Distributor
»Intake Manifold
»Alternator
i am stuck here, would i need new wires or not what else am i missing ? please help. </TD></TR></TABLE>
1 yo uwill need a conversion harness for the car/ecu (obd2 to 1)
you will also might need to rewire your injector plugs for obd2 other then that.. the radiator hose is just for the top one... so that it will fit fine.. any b16 radiator hose is what you can use/ i suggest for you to get a 99/00 SI raditor so the radiator hose fits "correctly" but its not really needed if your gonna hella clamp the hose LOL thats ghetto
you will also need to wire up vtec and knock sensor
and also need to get a 99/00 SI l bracket and driverside mount and 96+EX/SI
engine bracket
»Motor
»Stock Motor Mounts
»ECU
»Civic SiR Axles
»Shiftlinkage
»Distributor
»Intake Manifold
»Alternator
engine bracket
Re: My first swap questions... (ShowTymers619)
ok when the engine says it comes with the complete wiring harness.. that doesn't mean that it will come with the vtec , and knok sensor rewired ?
so this means i will have to do it ?
i know where to purchase a obd2 to obd1 harness, but where would i find something like this ?
* B A N N E D *
the wireharness if JDM its useless... except the using the plugs itself...
but.. you will most likely need to wire up those things.. you can cut off the plugs you need and wire them up to the ecu
honeslty.. to make things WORK easiet... buy yourself a 99 SI wireharness..it will save you the headaches
where would i buy one, just from like a junk yard, or the dealership..
or is there some web sight that speciallizes in on all the stuff u need for a swap .
* B A N N E D *
junkyard or here is your best chances ill try to find a few parts
youwill also need a obd2 distributor or re wire the obd1.. but distributor king .. look on the top page you will see there site flash....they have CHEAT brand new distributor..
https://honda-tech.com/zerothread?id=877565
South Bay Surfer
10-10-2002 05:05 PM
