someone please confirm this information i have
my buddy is putting a jdm b16a swap into his 92 cx hatch. i heard that u can use stock mounts with this. i have found some info on the mounts i just need someone to confirm that i got the mounts in the right order.
94-00 integra driverside with bracket
94-00 lower integra tranny mount
90-93 integra rear mount and l bracket
vtec del sol a/c bracket
a stock d16 upper tranny mount?
any help would be great
Re: someone please confirm this information i have (blueintegra90)
94-00 teg drivers upper mount works as does the alumnium civic mount 94-95
94-00 lower tranny mount is correct, but use the D shaped braket that mount to the frame rails from the civic
Use the B16 rear mount (on engine) and the civic bracket (on car)
P54 (94-95 del sol vtec ) AC bracket to retain AC. The teg bracket will work. Once again, use the D shaped braket that mount to the frame rails from the civic
Use the Teg upper tranny mount
alexsracing
01-02-2005 08:22 PM
