im a new kid with a question.... d16y8 swap into 95 dx coupe?
alright.. i have a newly rebuilt d16y8 and i plan to drop it into my 95 dx.. im keeping my obd1 harness and buying a p28 ecu.. i need to know if my 95 d15 flywheel will work on the y8 and also.. what do i do about the intake manifold, theres a lot more sensors that i dont need.. what do i do with them? or should i not use the y8 intake? thanks
* B A N N E D *
Re: (skaterdx)
p28? are you going conversion harness? .. well you need the btec wires wired up.. and also you will need...to change the IACV i think....but all of the sensors should all be reused
maybe im wrong about the p28.. i thought it was an ex/si 92-95 ecu.. and also theres some random sensor mounted on the middle of the fuel rail on the y8 and im not sure what to do with that, and another odd sensor near the crank by the harmonic.. not too sure what to do with that either.. so other than those everything but the iacv should work fine with an obd1 harness?
bunnyx
04-30-2008 01:53 AM
