car still runnin hot,fan wont turn on!
ok so i had the prob of my fan not turnin on a couple of days ago, i was told that i could jus jump it at the thermostat housing to see if the fan works at all, well it turned on when i jumped the harness so i bought a new fan temp switch, but after replacing it today the car still runs hot, not too sure what it could be now, any suggestions would help
Re: car still runnin hot,fan wont turn on! (wsiracerz)
ok so i just jumped the fan at the thermostat housing to double check an make sure it works an it came on, if i cant find the prob soon imma jus run the fan to a switch, any other suggestions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wsiracerz »</TD></TR><TR><TD CLASS="quote">ok so i just jumped the fan at the thermostat housing to double check an make sure it works an it came on, if i cant find the prob soon imma jus run the fan to a switch, any other suggestions</TD></TR></TABLE>
Bump: cause I have no clue. Check the fuses maybe? If all failes hook it up to a switch.
Re: car still runnin hot,fan wont turn on! (h22Hatchy)
i checked the fuses, and i wired it up to a switch for the time being until i can find the prob an fix
also i read this somewhere already but when i felt the upper radiator hose it was hot but when i felt the bottom it felt cooler?
ok even after swithin the fan to a switch an keepin it on it still gets hot so that is still not the prob, tomorow i will replace thermostat and fuse relay to c if that helps
Have you checked your coolant levels at all? If i remember correctly from what turbogixxer told me, your thermostat isn't working properly if your lower radiator hose doesn't feel "full" and get hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wsiracerz »</TD></TR><TR><TD CLASS="quote">also i read this somewhere already but when i felt the upper radiator hose it was hot but when i felt the bottom it felt cooler?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wsiracerz »</TD></TR><TR><TD CLASS="quote">ok even after swithin the fan to a switch an keepin it on it still gets hot so that is still not the prob, tomorow i will replace thermostat and fuse relay to c if that helps</TD></TR></TABLE>
Your Thermostat is not opening causing the Thermostat switch to read wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">] If i remember correctly from what turbogixxer told me, your thermostat isn't working properly if your lower radiator hose doesn't feel "full" and get hot.</TD></TR></TABLE>
Correct, it will not feel "full" But it will stay warm/cold (not hot). Basicly your motor sucks from the bottom of the Radiator and feeds coolant back to the top. Your Thermstat is on the bottom hose (on hondas).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]Have you checked your coolant levels at all?</TD></TR></TABLE>
Learning how to find the problem
Re: car still runnin hot,fan wont turn on! (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
Learning how to find the problem </TD></TR></TABLE>
Gotta check the easy stuff first.. lol. ***.
Re: car still runnin hot,fan wont turn on! (DarkKnight[DMD])
haha yea imma replace the thermostat in a little while an c if that does it, if it does then i can jus rewire my fan to normal again
wsiracerz
50
06-10-2004 12:09 PM
B_1_8_hatch
01-23-2003 07:03 PM
