b20vtec timing belt off half tooth
Old 05-31-2004, 08:41 PM
gsrvtechatch93's Avatar
Default b20vtec timing belt off half tooth
okay i have a built b20vtec with a vtec water pump. I am supposed to have a gsr timing belt right? im not sure if it is since i bought it from someone but if i was using the ls timing belt wouldnt it be more than just a half tooth off. my b20vtec is built with 12.5:1 pistons and skunk cams. could running the intake cam 5 deg. retarted hit the pistons i need help
Old 06-05-2004, 09:13 PM
bull2k4's Avatar
Default Re: b20vtec timing belt off half tooth (gsrvtechatch93)
i have a b20vtec.....used a ls water pump type r oil pump with an ls timing belt.....fits nice and snug no issues....when i had a vtec water pump with a gsr belt i was off about a half a tooth so maybe you are having the same problem i used to have....
rick_rabies
04-01-2009 12:59 PM
Justintegra
04-20-2008 12:46 PM
B18 CYA
05-11-2005 03:11 PM
EFOSV
06-16-2004 07:22 PM
JR Integra
05-03-2004 04:17 PM
Quick Reply: b20vtec timing belt off half tooth
