which sensor is this?
Old Jun 3, 2004 | 06:16 AM
shadykit's Avatar
Default which sensor is this?
Hey guys, what sensor is that under the intake manifold on the right hand side next to the alternator.
I'm wiring up my gsr ek swap and don't know what sensor that is??
There is also a sensor next to the pulley belt or whatever, I am using the stock ek
wire harness and it seems like I don't have a sensor for that one either? Do I need to extend a wire or add a wire to that..?
thanks
Old Jun 3, 2004 | 06:31 AM
EE_Chris's Avatar
Default Re: which sensor is this? (kitchale)
What are the wire colors for these two connectors?
You're probably talking about the KS (knock sensor) and the CKF (crank fluctuation).
Old Jun 3, 2004 | 06:40 AM
shadykit's Avatar
I don't know what color the wires are, I'll have to go home and check.
There should be a connector on the harness for those 2 sensors right?
Stock ek harness.
Old Jun 3, 2004 | 06:52 AM
shadykit's Avatar
Also which radiator hoses do I use cuz the integra hose are too big and the civic hoses are too small. Sup with that?
Old Jun 3, 2004 | 07:43 AM
EE_Chris's Avatar
Which "stock EK harness"?
Your original motor might not have had a knock sensor. You will def have the CKF connector though as all 96-00 Civic engines had'em.
Old Jun 3, 2004 | 07:47 AM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kitchale &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, what sensor is that under the intake manifold on the right hand side next to the alternator.
I'm wiring up my gsr ek swap and don't know what sensor that is??</TD></TR></TABLE>
Sounds like IAB, but be more specific with plug & wire colors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kitchale &raquo;</TD></TR><TR><TD CLASS="quote">There is also a sensor next to the pulley belt or whatever, I am using the stock ek wire harness and it seems like I don't have a sensor for that one either? Do I need to extend a wire or add a wire to that..?
That's the crank angle sensor. If you don't have that hooked up, then the car won't start.
Old Jun 3, 2004 | 08:14 AM
shadykit's Avatar
What are the color wires for the Crank senor, I dont think I have that label on my wire harness.
And the sensor under the fuel rail behind the IM is th IAB? Ok I will check that out 2day.
thanks
Old Jun 3, 2004 | 09:15 AM
philipkrotch's Avatar
sounds liek a knock sensor to me.
lurchy
Honda CR-V & Element
May 17, 2016 08:06 AM
rick_rabies
Jul 2, 2009 09:39 PM
sexyazz_ek
Jun 9, 2007 12:20 AM
CrazyHB
Aug 30, 2004 12:15 PM
importneeds
Feb 15, 2002 01:47 AM
