VTEC engagement problem
Old Nov 16, 2004 | 07:03 AM
92eg'n's Avatar
Default VTEC engagement problem
I am having a problem with my vtec cutting out as I climb through rpms...I have good oil level, wiring is good, brand new vtec solenoid, and i hava already tried a different ecu to see if that was the problem...but the problem still persists...any help with this matter would be great thanks...the motor is a b16a2 in a 92 civic hb cx...anyone help please...
Old Nov 16, 2004 | 07:16 AM
92eg'n's Avatar
Default Re: VTEC engagement problem (92eg'n)
Old Nov 16, 2004 | 07:42 AM
92eg'n's Avatar
Old Nov 16, 2004 | 10:12 AM
92eg'n's Avatar
Old Nov 16, 2004 | 10:54 AM
92eg'n's Avatar
no help anyone...i will try anything if you think that it can fix the problem...
Old Nov 16, 2004 | 11:21 AM
92eg'n's Avatar
Old Nov 16, 2004 | 11:25 AM
endlesswinterco's Avatar
what do you mean cutting out through rpm, does it not engage at all or is it on, then off, then on kinda of a thing?
Old Nov 16, 2004 | 11:49 AM
92eg'n's Avatar
Default Re: VTEC engagement problem (RidinlowHatch)
on then off, then on....
Old Nov 16, 2004 | 12:55 PM
92eg'n's Avatar
000000000
Old Nov 16, 2004 | 01:44 PM
92eg'n's Avatar
bump to the top
Old Nov 16, 2004 | 08:37 PM
95excoupe's Avatar
Check the pins of the plug that connect to the vtec soleniod and vtec pressure switch. Make sure they are clipped on tight and the pin isnt loose inside the plug...thats all i can think of good luck to you
Old Nov 17, 2004 | 03:40 AM
92eg'n's Avatar
Default Re: VTEC engagement problem (95excoupe)
thanks for all the help guys I hope that I can fix it now..
Old Nov 17, 2004 | 07:37 AM
bb6's Avatar
bb6
BUMP
Old Nov 17, 2004 | 10:08 AM
92eg'n's Avatar
Default Re: VTEC engagement problem (bb6)
Old Nov 17, 2004 | 11:16 AM
slthatch's Avatar
check your speedometer
Old Nov 17, 2004 | 12:33 PM
92eg'n's Avatar
Default Re: (slthatch)
i am thanks dude...
Old Nov 18, 2004 | 03:14 AM
92eg'n's Avatar
Old Nov 18, 2004 | 06:29 AM
spoonek9's Avatar
Default Re: (92eg'n)
Try a different distributor if you can. I had problems similar to yours and it turned out to be the distributor. Good luck
Old Nov 18, 2004 | 10:30 AM
bb6's Avatar
bb6
Default Re: (spoonek9)
bump
Old Nov 19, 2004 | 05:18 AM
92eg'n's Avatar
Old Nov 21, 2004 | 01:52 PM
92eg'n's Avatar
bump...thanks for all the info everyone is giving me...still isnt working right but hopefully I can figure it out soon...
Old Nov 21, 2004 | 02:09 PM
Kamin's Avatar
http://info.honda-tech.com/ind...oting
Old Nov 22, 2004 | 06:23 AM
92eg'n's Avatar
Default Re: (Kamin)
that article was very helpful...but I am giving up on the problem...thanks for everyones help...and I hope that if some one is having a similar problem that info provided in the thread will help fix it...
Old Nov 30, 2004 | 09:57 PM
CRXLST's Avatar
what weight oil are U using in your engine??? 10-30 I bet???
Old Dec 1, 2004 | 06:38 AM
C M S's Avatar
Default Re: (CRXLST)
My buddy's car had the same prob, turned out it had a weak/bad alternator.
