obd0 n obd1 dizzy
obd0 n obd1 dizzy
can sum1 please show me pics of the 2 distributors and tell me the diff between them. i don noe what kind of dizzy i have on my b16
Re: obd0 n obd1 dizzy (teggytegteg)
The obd0 will have whitish/yellow plugs and the OBD1 will have Grey plugs. They are not interchangeable. I can convert the OBD1 to OBD0 though
Phil
Phil
Re: obd0 n obd1 dizzy (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">The obd0 will have whitish/yellow plugs and the OBD1 will have Grey plugs. They are not interchangeable. I can convert the OBD1 to OBD0 though
Phil</TD></TR></TABLE>
All that takes is some repinning. Not that hard.
Re: obd0 n obd1 dizzy (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
All that takes is some repinning. Not that hard.</TD></TR></TABLE>
I never said it was hard but, he may not know how.
Phil
Phil
from my understanding either the top dead center sesor or cylinder position sensor has a different number of teeth on the gear in OBD0, so you cant just repin OBD1/OBD0 to work with the opposite ECU
Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">from my understanding either the top dead center sesor or cylinder position sensor has a different number of teeth on the gear in OBD0, so you cant just repin OBD1/OBD0 to work with the opposite ECU</TD></TR></TABLE>
I never said you could make them run on the opposing ECU's just that I can make the OBD1 plug into the obd0 harness and look factory if converting to OBD1.
Phil
Phil
Location: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggytegteg »</TD></TR><TR><TD CLASS="quote">hey man thnks for the picss really appreciate it</TD></TR></TABLE>
ask and you shall receive
Re: obd0 n obd1 dizzy (crxhybrid85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhybrid85 »</TD></TR><TR><TD CLASS="quote">Will a OBD 0 distributor work on a OBD 2 motor with an OBD 0 ECU?</TD></TR></TABLE>
Yep .
Yep .
ludesrv
05-12-2007 08:58 PM
