cel code help
Old Oct 31, 2004 | 02:54 PM
b16clutch's Avatar
Default cel code help
anyway to bypass or disable the crankshaft speed fluctuation sensor....car is a 96 civic coupe, obd1 b16 swap.....98 gsr computer.....cant seem to turn off the code cause the motor sure doesnt have the sensor....
Old Oct 31, 2004 | 05:41 PM
Katman's Avatar
Default Re: cel code help (b16clutch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16clutch &raquo;</TD></TR><TR><TD CLASS="quote">anyway to bypass or disable the crankshaft speed fluctuation sensor....car is a 96 civic coupe, obd1 b16 swap.....98 gsr computer.....cant seem to turn off the code cause the motor sure doesnt have the sensor....</TD></TR></TABLE>
there's no way to disable it as your setup stands.
YOu have 2 options:
1) run a JDM OBD2 ecu
2) convert to OBD1 (meaning you need to an OBD2b-&gt;OBD1 jumper harness & OBD1 GSR ecu).
Old Nov 1, 2004 | 07:00 PM
b16clutch's Avatar
Default Re: cel code help (K@man)
thanks for the response....got it done now, converted to obd-1 today
h22integra.eire
Engine Management and Tuning
Sep 14, 2015 06:08 PM
hatchback freek
Dec 28, 2007 05:19 PM
beseman
Aug 24, 2006 10:18 AM
JDM Vision
May 3, 2006 05:09 AM
Boost2NA
Aug 29, 2004 08:15 PM
