b18a swap in eg
b18a swap in eg
first off i have a b18a in a 93 coupe, all hooked up and ready to go the only problem is none of my distubutors work i have a b18c1, h22, f22, d16 all obd1, they all fit but none line up with the bolt hols any ideas?
should i just swap out the insides of the original and use that housing?
thanks
thanks
Re: b18a swap in eg (packman)
i have the same thing. i used a b18c1 distrib and it works fine. unfortunately, only one of the bolt holes lines up (the one on the top). it is solid tho w/only 1 bolt holding it on. it doesnt shake or move at all.
unknown0001
01-24-2006 07:02 PM
