H22 EG swap, WTF is this black box??????
I am in the middle of my h22 swap into my EG hatch and i noticed that this little black box had a hose thing broken off. What is it and do i need it????
Re: H22 EG swap, WTF is this black box?????? (delLudeVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC »</TD></TR><TR><TD CLASS="quote">mine was broken off also when i got my motor </TD></TR></TABLE>
I have an entire stock manifold for sale. PM me with an offer.
Re: H22 EG swap, WTF is this black box?????? (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe »</TD></TR><TR><TD CLASS="quote">just get rid of it. You dont really need it.</TD></TR></TABLE>
Re: H22 EG swap, WTF is this black box?????? (DarkKnight[DMD])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]
its still there but i dont have my IABs connected because i will be going with the skunk 2 manifold anyways. So i will pull it off when i swap em out.
Re: H22 EG swap, WTF is this black box?????? (enigma94)
You dont need it. Its good to have but if u dont have the box just hook the secondaries up by a vacuum line.
yeah, you dont need that goofy thing, iab's are waaaaaaaaaaay overrated, lol. Are you planning on doing the skunk2 before you drop the motor in? Hope so, its a tight squezz back there.
Re: H22 EG swap, WTF is this black box?????? (AudioFuct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioFuct »</TD></TR><TR><TD CLASS="quote">yeah, you dont need that goofy thing, iab's are waaaaaaaaaaay overrated, lol. Are you planning on doing the skunk2 before you drop the motor in? Hope so, its a tight squezz back there.</TD></TR></TABLE>
Just like removed the balance shaft belt? 1-3whp will make a difference in our cars. When you are only working with 170-190whp, believe me, they can make a difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioFuct »</TD></TR><TR><TD CLASS="quote">yeah, you dont need that goofy thing, iab's are waaaaaaaaaaay overrated, lol. Are you planning on doing the skunk2 before you drop the motor in? Hope so, its a tight squezz back there.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]
Just like removed the balance shaft belt? 1-3whp will make a difference in our cars. When you are only working with 170-190whp, believe me, they can make a difference.</TD></TR></TABLE>
Stop beating a dead horse.
Re: H22 EG swap, WTF is this black box?????? (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
Stop beating a dead horse.</TD></TR></TABLE>
Get a life?
By the way, your start up fix didn't fix my start up. The only reason it seemed better at the time was b/c the motor was warm.
Get a life?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]By the way, your start up fix didn't fix my start up. The only reason it seemed better at the time was b/c the motor was warm. </TD></TR></TABLE>
Got a fix for that too.
Got a fix for that too. </TD></TR></TABLE>
A fix to fix the fix that wasn't really fixed?
A fix for the original fix that didn't work?</TD></TR></TABLE>
It is two difterent settings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]Did you fix the idle surging though?</TD></TR></TABLE>
Working on that. It will get fixed.
so what exactly does this box do b/c i just ripped it off. i am throwing three codes, could this box be one of them?? codes are: 12 - 14 - 41. thats the egr - IAC(EACV) - and primary o2. any ideas??
Re: H22 EG swap, WTF is this black box?????? (alleyezonme)
sorry not trying to jack this thread... i thought my situation might help you decide if you want it in there or not too, cause if i am throwing a code then why not keep it in... i don't think it hurts anything, just not sure if it HELPS.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alleyezonme »</TD></TR><TR><TD CLASS="quote">so what exactly does this box do b/c i just ripped it off. i am throwing three codes, could this box be one of them?? codes are: 12 - 14 - 41. thats the egr - IAC(EACV) - and primary o2. any ideas??</TD></TR></TABLE>
No, that box has nothing to do with the codes you're throwing. Do you have egr hooked up? Did you lengthen your IAC wiring? Also, did you wire your 02 sensor correctly?
1 Post
I have the same 41 code after H22 swap in Del Sol SOHC. Using stock SOHC engine wiring.
Try everything nothing help. Then find out that there no independent + on ECU after swap. Each time when ignition off and on ECU reseting. Strange, but I did not touch the under dash board wiring.
My black box pins was broken too. I was using the M6 bolts, drill the hole thrue the bolt. Dril directly trhue the bolt length, like chanel. Then screw it in the black box with glew in old places, before that I was cuted off old broken conection. Conect all vacum lines as they must be. But still don't understand the functionality of that devaice.
My friend recive the 5gen lude from USA with H22A4. This black box instaled near batery, not under IM. And there is vacum valve too like on secondaries TB!!!
Nothing conected at this valve, we decide that there was something on stock intake plastic tube. and something was moved buy the help of this valve. There are now AEM CAI.
Pic of car, maybe some one recognize this one:
