Anyone ever get the clips off the injector harness?
Is there a trick to getting the pins out of the clips for the injectors? I dont see a release on them and i dont want to break it. Its a 96 civic with a 95 gsr motor and the 96 harness doesnt support obd1 injector clips. Also all the other wiring has turned out to be the biggest bitch ever they are all traced back to the ecu so it should work but I had no idea it was this much of a hassle to wire in a newer ek harness onto an older gsr motor. Well any help would be appreciated
Re: Anyone ever get the clips off the injector harness? (95excoupe)
I just pulled them out on each side of the harness clip with a flat head screw driver. no harm done wen I did it. I think thats how ur suppose to do it.
Re: Anyone ever get the clips off the injector harness? (Sixgundone)
Ok thanks ill have to give it a try. If I cant get it is there any harm in cutting these and soldering on the right ones?
are u talkin about cutting the harness and putting the right clips on the harness? if so I am pretty sure u can do it cause there is a guy that told me that he would have to use my stock wiring harness on my swap and cut some connectors off my other harness. I have a jdm OBD1 harness if u need one. Its for a prelude swap though.
satitus
06-21-2005 12:45 PM
