b18a in 95 civic, ECU and Harness?
this is my first attempt for a swap. could someone point me in the correct electronic direction? what ecu and wiring harness is neccessary to install a 91 b18a in a 95 civic dx. thanks
Re: b18a in 95 civic, ECU and Harness? (purge)
the 91 b18a, if i recall correctly, is obd0. the 92-93 b18a's, however, are obd1. your civic is obd1. my suggestion would be for you to get a 92-93 b18a or obd1 b18b intake mani/tb and an obd1 b18a/b18b engine harness. you can use your stock civic engine harness as well. the oxygen sensor wires would need to be extended tho to reach the oxygen sensor on the b-series exhaust mani. dunno if any other mods would have to be made. i just used a b18a obd1 harness.
you'll also need to get a PR4 obd1 integra ecu (so the ecu out of a 92-93 or 94-97 integra). also, the driv side eng mount bracket needs to be replaced with a 94+ integra bracket. and you'll need a b18a throttle cable. obviously you'd need a hydro b-series tranny as well. good luck for the money a b18a costs, its a pretty damn good swap.
Re: b18a in 95 civic, ECU and Harness? (dlric)
thanks for the help. i have a pr4 and b18a out of a 91 integra but i thought that the pr4 was an obdo. someone had suggested the p72 was the way to go. any thoughts? also whats the difference between the 90-91 and the 92-93 manifolds?
for the b18a obd I you need a p74 ecu or an obd I p75. The 90-93 teggie IM are a bitch to work with, too many different sensors and vacume hoses that you don't need, I'd get a complete 94 teggie ls IM complete with sensors(this can be from automatic ) but the TB has to be from 5spd. Make sure your ecu is from a 5spd teggie aswell. you can use the cable tranny with a conversion kit from hasport but your engine will be jerky on starts and b/t with the loss of the lower front tranny mount. You will also need the rear engine mount bracket from a 5spd 94+ teggie. This will give you a complete plug and play set up with the exception of a few sensors that will need to be extended. No relocating of map sensors or vaccume hoses. Heres a list of what you need to make your engine OBDI
94-95 ls or gsr injectors
94-95 ls dizzy
94-95 alt.
if you want ac you need an ac bracket from a 94 dohc vtec del sol or a front a/c bracked of a 94+teggie if you dont mind the loss, either way you'll need it, it's also a mount bracket for the lower front dampner.
I've heard the 91 ls shifter linkage will work si if it's free I'd try it before I bought some for the 91+ teggie.
Hope this helps. I would personally wait til you find a hydro OBD I swap, unless you paying @6-700 for the swap it's not really worth it for all you need to make it work.
94-95 ls dizzy
94-95 alt.
P72 is a vtec ecu(gsr I believe), p74 and obdI p75's are @ the same except the p75 also came in obdII. The p74 and p75 are non-vtec ecu's. Just remember when changing the obd of the engine every thing must match ecu, injectors, and dizzy.
