o2 sensor location on b18c swap in 95 hatch
I'm having a 95 b18c installed in my hatch. I just received my dc header in the mail today. I noticed there is no bung for a 02 sensor. The engine is at the shop who's doing the install. I never really noticed the location of the 02 sensor. Is the 02 sensor on a b18c after the cat on the stock exhaust? I guess I will have to have a bung welded on the catback exhaust for the hatch or on the cat or test pipe. Will I have to extend the 02 wires? Or I should say the shop.
Re: o2 sensor location on b18c swap in 95 hatch (Spins)
if you use that header or oem. you should try to get the gsr cat as that has the O2 bung in it. if not you will have to either add a bung in the dc header or in the cat.
EFstyle
08-25-2006 11:26 AM
