HELP: Timing Marks
Old Nov 8, 2004 | 12:03 PM
SloCivicHMM's Avatar
Default HELP: Timing Marks
https://honda-tech.com/zerothread?id=1049239
sorry cross posted it cuz I shoulda posted it here first.....let me know if you guys can help me out...
Jose
Old Nov 8, 2004 | 12:21 PM
owen_the_soyboy's Avatar
Default Re: HELP: Timing Marks (SloCivicHMM)
the keyway on the crank pulley locates it on the crank in relation to the timing belt gear as well.
do you have both crank pulleys to compare?
if so, look thru their center holes and line up the keyway (where you put the woodruff key) then mark the new pulley.
if you dont, you ned to know if the timing is the same between those motors and also if the keyways are in the same spot. I bet its close if not all the same but hell, what do I know.
Old Nov 8, 2004 | 12:30 PM
Default Re: HELP: Timing Marks (owen_the_soyboy)
so the key marks 16 degrees ???
so once my crank lines up with the mark on the block for TDC where that key is relative to the edge of the pulley thats my 16 degree mark to work off when setting my timing?
I hope I have the old pulley....hehe
keep it coming uys....I'll try to get pics to help me out..
Old Nov 8, 2004 | 02:34 PM
bump before I leave work...
Old Nov 8, 2004 | 04:12 PM
Lord Helmet's Avatar
like owen have said, compare the old pulley with the new pulley to see if they match. I've compared a D16z6 to a B18c1 pulley before and they have the same similar marking at the same place for the timing so I am "guessing" they are equally the same with your zc and sohc pulley *crosses fingers*
Old Nov 8, 2004 | 07:55 PM
Default Re: HELP: Timing Marks (sleeperciv)
thanks guys, I'll check it out soon....**** came up tonite and couldn't get in the garge...
Old Nov 9, 2004 | 07:40 AM
Dueceification's Avatar
to after market pulleys. Though my unorthadox was not off. My friend has one that was way off. how can they make such shitty products. I swear the only good parts u can get are from honda. Then again you are putting it on a different motor.
Old Nov 9, 2004 | 07:59 AM
Default Re: HELP: Timing Marks (93b16hatch)
well the ZC is the black sheeep.....
but mines na Unothodox Racing Street Pulley, been on for 25k and like 7 days of track abuse....still going strong......
KEep you guys updated...thx for the help!!
Civic-Kids
Mar 12, 2009 01:45 PM
SloCivicHMM
Nov 8, 2004 02:30 PM
Nick248
Sep 9, 2002 09:59 PM
