Resistor Box Problems
Old Jan 31, 2006 | 01:28 PM
SupraRXZ's Avatar
Default Resistor Box Problems
I just read a page saying I dont need a resistor box for the b18b1 swap into a DPFI EF9 . So do you know for sure if I need one or not?
Old Jan 31, 2006 | 05:41 PM
thumbtack's Avatar
Default Re: Resistor Box Problems (SupraRXZ)
no you don't need it. It is High Impedance injectors. Thus not requiring the resistor box.
Old Jan 31, 2006 | 06:28 PM
SupraRXZ's Avatar
Default Re: Resistor Box Problems (thumbtack)
even if im running it on OBD0?
Old Jan 31, 2006 | 08:23 PM
thumbtack's Avatar
yes even obd-0.... you need to solder the injector power wires together to the one red wire going into the resistor box. Take all 4 of the injector POWER wires, and solder them to the ONE RED POWER wire going into the resistor box... that is all you have to do... now you can run obd1+ injectors if you wish to do so.
Old Jan 31, 2006 | 08:24 PM
thumbtack's Avatar
that is if you are running an obd0 ecu and obd1 or 2 injectors. OBD0 injectors WILL NEED the resistor box
Old Jan 31, 2006 | 08:45 PM
SupraRXZ's Avatar
motor and ecu is going to be obd0...dizzy,alternator,intake mani, and ecu
so I need a resistor box then rite?
Old Jan 31, 2006 | 09:07 PM
thumbtack's Avatar
if you're using OBD-0 Injectors they yes.
92 teggy
13
Feb 22, 2010 08:22 PM
SiR eF_4door
Jul 25, 2009 10:58 AM
apekd
13
Dec 30, 2008 10:47 AM
immorality
May 24, 2008 03:46 PM
Butch
May 16, 2003 08:49 AM
