H22 wiring problems / distributor ??
Old Feb 5, 2006 | 08:27 PM
jellyroll's Avatar
Default H22 wiring problems / distributor ??
I have a 98 accord with a 99 h22a4 running a obd2 to obd1 wiring harness and a p28 and also using a p13 its all in everything is hooked up but the car idles at like 1500rpm cuts out when i get on it... i think the iacv is fine.. the timing seems right but when i check it with a timing light the line (the 15 on the flywheel) bounces a little bit and the only code im throwing is 6 the temp sensor i have no idea what to do. i think i might have wiring the distributor wrong can someone tell me what wires go where or have any idea whats the deal????
Old Feb 5, 2006 | 09:12 PM
hondaZvic's Avatar
Default Re: H22 wiring problems / distributor ?? (jellyroll)
https://honda-tech.com/zerothread?id=650329 this may help u. there is alot of distributor pinouts here. you may want to compare them with some accord pinouts and see what you can come up with.
Old Apr 17, 2006 | 03:47 PM
RaceCarRyne's Avatar
bump
ozzyman
Oct 1, 2003 09:52 AM
