Knock sensor problem on my h22a
Old Feb 1, 2006 | 11:10 AM
deucedeuceEK9's Avatar
Default Knock sensor problem on my h22a
i have been getting knock sensor code(23) on my p13 and i cant figure it out i re ran the wire directly from the knock to the ecu and its still throwing the code, what can it be do i just need a new knock? what negative effects is this knock code causing to my performance
Old Feb 1, 2006 | 11:16 AM
IHateJDM's Avatar
Default Re: Knock sensor problem on my h22a (deucedeuceEK9)
its retarding your timing to protect the motor from detonation. First off, are you sure its not detonating?
Old Feb 1, 2006 | 11:18 AM
the motor runs really strong i with the code it ran a 13.9
Old Feb 1, 2006 | 11:46 AM
can anyone help me?
Old Feb 1, 2006 | 11:47 AM
xv53's Avatar
Default Re: (deucedeuceEK9)
did you use a sheilded wire to run from the knock sensor to the ecu?
Old Feb 1, 2006 | 11:57 AM
no, i didnt just regular 18 gauge wire, does that matter
Old Feb 1, 2006 | 11:58 AM
v4lu3s's Avatar
RTFM
honda didnt spend the extra money to use a shielded wire just to spend money.
Old Feb 2, 2006 | 12:13 PM
kurtywompus's Avatar
Default Re: (v4lu3s)
ok so what kind of shielded wire should i use to make the connection for the knock sensor? i cant remember seeing it on the h22/eg swap page.
how sensitive does it have to be... can i just bumble through this and solder like the monkey i am....
you guys have me thinking and second guessing myself.
sir2sol
May 12, 2007 05:32 AM
ddong2lee
Mar 4, 2004 05:06 AM
EF_LSVtec
Apr 10, 2003 11:25 AM
speshuled619
Jul 26, 2002 10:23 AM
speshuled619
Jul 25, 2002 05:12 PM
