Please help with clutch line! h22 swap
Hey So I'm currently trying to put my swap together and have another question. So on the engine from the slave cylinder I have the clutch line, now it's cut about half a foot from the slave cylinder, and only has the rubber part of the hose on it. And the clutch line from my integra is braided steel. What do I do? I don't think the braided line will work going into the rubber line. Any help would be great!
Shooting Star
does your braided line from your integra have a fitting on the end of it? If the rubber one comes off then see if your braided will match up if not then get some sort of coupling that will take the threads of your braided hose and make it possible to screw to your trans.
Re: (vtecspeed1320)
Yeah the end of my integra clutch line is braided with a fitting on the end. The thing about the clutch line is it's really reinforced and I wouldn't be able to stick anything in there because it has such a small opening.
B18c5__Owns
03-25-2009 12:48 PM
BIGBLOCKEK
09-06-2004 11:14 PM
