Will a b18b dizzy work on a b18a engine?(electronically)
Old Jan 23, 2006 | 08:17 PM
unknown0001's Avatar
Default Will a b18b dizzy work on a b18a engine?(electronically)
hey guys I've tried to search for this answer but couldn't find anything.
I know the b18b dizzy will bolt onto the b18a head but will it use the same connectors?
This swap is going into my EG and just wondering if I can use a b18b dizzy on a b18a engine.
thanks
Old Jan 23, 2006 | 10:29 PM
Geno's Avatar
Default Re: Will a b18b dizzy work on a b18a engine?(electronically) (Mr.RHTuner)
If you switch the plugs, yes.
Old Jan 24, 2006 | 05:43 AM
EFvtec Yo!'s Avatar
If the b18b dizzy is an obd1 dizzy it should plug and play considering your car is an eg and it is obd1.
Old Jan 24, 2006 | 03:01 PM
Default Re: (EFvtec Yo!)
The dizzy is off a 1996 Integra so that's OBD II correct?
what would I need to do to make it work?
Old Jan 24, 2006 | 07:02 PM
EFvtec Yo!'s Avatar
Default Re: (Mr.RHTuner)
Yeah a 96 LS would be obd2. You could just cut and splice an obd1 plug onto the dizzy to work with your harness or you could maybe repin your dizzy plug on your harness to work with the obd2 dizzy.
AdrenalineAngel
Oct 27, 2012 08:25 PM
lsvtec_hatchback
Apr 28, 2009 09:11 AM
D1andOnly
Nov 26, 2005 07:21 AM
gildo86
May 31, 2004 11:41 AM
superstud
Nov 11, 2003 01:07 AM
