knocking from where help
Old Jan 31, 2006 | 06:08 AM
gato5254's Avatar
Default knocking from where help
i have a 96 itr engine in a hatch 96. I didn't have the air intake temp sensor connected for about 4 months because when I got it swapped I didn't really check for anything. But now when i wired it up and reset the ecu the car starts fine with no codes, but when i rev it up a couple of mins later i throw the knock code. But if don't connect the air intake temp sensor the knock doesn't go off. Can anyone please help i just adjusted my valves and they needing adjusting but it's still knocking.
Old Jan 31, 2006 | 06:14 AM
migs's Avatar
Default Re: knocking from where help (gato5254)
You sure you have the right plug plugged in to the IAT? There are about 2-3 plugs in that area that look the same. Better check that, you can fry a portion of your ECU if the wrong plug is plugged in. Trust me, I know from experience.
Old Jan 31, 2006 | 07:40 AM
JjuuN R's Avatar
Default Re: knocking from where help (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">You sure you have the right plug plugged in to the IAT? There are about 2-3 plugs in that area that look the same. Better check that, you can fry a portion of your ECU if the wrong plug is plugged in. Trust me, I know from experience. </TD></TR></TABLE>
d0h!!
Old Jan 31, 2006 | 09:35 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: knocking from where help (JUN.R)
Isnt the IAT the same as the map and TPS?
Old Jan 31, 2006 | 10:13 AM
migs's Avatar
Default Re: knocking from where help (walker111)
I beleive the knock wire is the same too.
Old Jan 31, 2006 | 10:34 AM
gato5254's Avatar
i think i connected everything right i went off a helms manuel and here is what i know. connector D; Knock sensor wire is red/blue so i know i didn't connect IAT sensor to that, the IAT wire color is red/yellow and the other ground SG2 wire color is green and black. both wires i got from the harness, i opened it up near where the battery goes and got the wires from there and ran the to the IAT sensor. I was talking to my friend and he said maybe i need better gas i'm running 91 always have, i'm going to try an octane booster this weekend. any ideas
here is a link to explain what i'm talking about.
http://www.ff-squad.com/technet/wiring.obd2a.htm
Old Feb 1, 2006 | 08:20 AM
gato5254's Avatar
bump
Old Feb 1, 2006 | 08:28 AM
cool guy name
1) no bumping
2) This doesnt belong in this forum in the first place
3) What ECU are you running?
4) If it wasnt throwing a code in the first place, why mess with it?
5) I take it this is a JDM motor?
Old Feb 1, 2006 | 10:09 AM
gato5254's Avatar
what forum does it go in yes it is a jdm motor I'm running the stock ecu for the motor. is was throwing a code. code 10 then i fixed that code and it starting code 23 knock. i would start it no codes step on the gas and go around block then the knock code goes off. so i check everything and my valves need adjusting so i adjusted them. reset ecu, same thing started the car no codes go around the block and knock code again. BUT if I unplug the IAT senor, i just throw that code BUT no knock. So i don't know whats going on. I mean Knock or IAT, it's one or the other but not both. any explanation for this. because i wanted to get some work done and buy some parts but i want the engine running good. I don't want to blow it up or hurt.
CBURKE
14
Jun 13, 2007 10:25 AM
gato5254
Feb 17, 2006 07:35 AM
crx-treme
15
May 8, 2005 11:21 PM
handa
16
Aug 12, 2004 07:12 PM
DLB1994
Aug 18, 2002 03:29 PM
