b16/gsr hybrid
b16/gsr hybrid
i'm not sure about what timing belt to use.
say i have a b16 head with gsr block/gsr oil pump.
the gsr block has a gsr water pump, but i have a b16 timing belt, and a new b16 water pump. is there anyway to use the b16 timing belt with any kind of oil/water pump combo?
Re: b16/gsr hybrid (del slw)
I belive you need to have matching oil and water pumps and the belt for whatever combo use go with.Someone correct me if im wrong.
you need a GSR/P72 timing belt with this type of head & block combo because a GSR short block is 7mm taller than a B16A block. There's no combo of pulleys that will allow you to use teh B16A timing belt with this motor setup...
ricin4ever
06-20-2008 09:31 PM
