all lights dim
Old Jan 25, 2006 | 01:08 PM
up's Avatar
up
Default all lights dim
Recently put a 97 gsr in a 00 civic dx.
For some reason, when I gas it, the lights dim - headlights, dash, cluster, radio - all of it. Then, as I move up in the RPM, after a certain RPM the lights all come back to being fully lit.
If, for example, I'm in 2nd gear and I gas it, all the lights are dim. Then, let's say I'm at 25mph and I let go of the gas (to engine brake or what not), after about 2 seconds, all the lights are fully lit again. If I gas it again, the lights go dim again. Then if I floor it, after a certain RPM, all the lights are back on until I shift into 3rd. Same thing for all gears pretty much.
What could the problem be? The guy who installed my motor hadn't even heard of this problem before, and he's been doing swaps for a long time now (and is also a member of this board). Any insight will be greatly appreciated. Thanks.
Old Jan 25, 2006 | 08:05 PM
up's Avatar
up
Default Re: all lights dim (up)
did i post this in the wrong section? if so, can someone kindly direct me to the proper section?
i'd like to fix this but i don't know what the problem might be. thanks.
Old Jan 28, 2006 | 08:23 PM
ej8slim's Avatar
I have the same swap and I'm trying to figure it out
Old Jan 29, 2006 | 07:01 PM
up's Avatar
up
Default Re: all lights dim (smokin_purp)
is this a common occurrence?
Old Jan 30, 2006 | 07:51 AM
intech's Avatar
same thing happen when i swaped my 98 gsr with a jdm 98 itr. i thought it was my sound system so i intalled a capaciter. it didnt help, i dont know why but i think it i need a higher output alternater....the one i have now is working to normal specs but i think something might be pulling more power than it should. might be my HID lights. but i dont know jsut guessing.
Old Jan 30, 2006 | 02:57 PM
JDMFreak's Avatar
Default Re: (intech)
i am having the same problem as well. what i done so far, is change battery cables, i changed alternator, and checked all of my grounds i even changed battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intech &raquo;</TD></TR><TR><TD CLASS="quote">might be my HID lights. but i dont know jsut guessing. </TD></TR></TABLE>
hehe i have HID as well, but i doubt it your/our HID. can someone enlighten us? BUMP
Old Jan 30, 2006 | 03:36 PM
aquabob89's Avatar
* B A N N E D *
Default Re: (JDMFreak)
why dont you get two batteries
Old Jan 31, 2006 | 08:56 PM
JDMFreak's Avatar
Default Re: (aquabob89)
bump for some help, aquabob didnt help much
Old Feb 3, 2006 | 05:52 AM
whitelightning's Avatar
i've had the same problem since 1997, and has been really buggin lately...i'm gonna keep an eye on this post...
updated...
i read the following post:
https://honda-tech.com/zerothread?id=838099 has anyone tried removing the alt-c wire?
Modified by whitelightning at 7:28 AM 2/3/2006
maxwellmercer
Oct 25, 2008 08:59 AM
JeremicaM
Honda Civic (2001 - 2005)
Feb 2, 2008 01:47 PM
existanzcivicb20
20
May 19, 2006 03:59 AM
ChargedLude97
13
Feb 12, 2004 01:57 PM
[626]phixionEF91
20
Feb 8, 2003 03:03 PM
