Gsr swap stock p28 aftermarket fuel system hard to start
* B A N N E D *
I have a stock p28 on a gsr swap and upgraded fuel system . Stainless braided from firewall to str/bdl fuel with aem FPR stock setting with vacuum hooked up , braided back to return line. ALso have the breather line exposed , no canister. When i turn the key on i hear the fuel pump kick on , i try to start and it will stumble and shut off , sometimes dont start at all first try. If i key it a few times and get the pressure built up i guess, it will then start normally most of the time. What would cause this? Is it the p28 not giving the initial pulse to the injector not good enough? Or does my aftermarket fuel system have something to do with it? Also does anyone know what kinda fuel pressure i should have with this. This is just a temporary ecu to work these kinda details out before i put the AEM ecu in.
Re: Gsr swap stock p28 aftermarket fuel system hard to start (crxsiperf)
i say put the aem ecu in don't tune your car with a different ecu than you plan on running or everything will change and you will be re-tuning your car
* B A N N E D *
Re: Gsr swap stock p28 aftermarket fuel system hard to start (boosted_93)
I haven't had a chance to even get outside to mess with it. Its bitter cold and snowing here in pa. I wish i had a damn garage
ColombianEk9Boy
12-18-2014 12:40 PM
Powered By Garrett
Engine Management and Tuning
06-15-2008 09:03 AM
crxsiperf
02-02-2006 05:31 PM
