Running obd1 injectors with obd0 ecu
Iv heard of a few people doing this by just removing the resistor box is this true and will it be fine on the ecu, I thought that it would mess up the injector drivers in the ecu by running the wrong injectors...
Thanks people in advance
Re: Running obd1 injectors with obd0 ecu (4thgenhtch)
What you need to do, is remove the resistor box, there are 4 injector power wires... I think they are black and yellow. Take them and solder them together then solder them to the one single red power wire to the resistor box. That is all you have to do.
Make sure you are using the obd1 injectors too. You will have to modify the inside of the clip on the injector for them to work with the obd-0 injector clips. OR just get some obd-1 injector clips from the junkyard. They are all the same.
shauniewalnuts
11-22-2004 07:15 PM
