h/f swap into a ef civic. wiring questions.
i got my 98 f23 accord motor from a salvage company online. when it came all the plugs were cut. so i have a motor with plugs that arent usable and no harness. do i need to get a wire harness for this motor or am i good?? motor is going in a 90 civic si hb .thanx in advance.
Re: h/f swap into a ef civic. wiring questions. (89a6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89a6T »</TD></TR><TR><TD CLASS="quote">i got my 98 f23 accord motor from a salvage company online. when it came all the plugs were cut. so i have a motor with plugs that arent usable and no harness. do i need to get a wire harness for this motor or am i good?? motor is going in a 90 civic si hb .thanx in advance.</TD></TR></TABLE>
The best way to do it is to use the harness that came with the chassis.. so you are in luck!
That way you just plug in your OBD0 to OBD1 adapter harness and modify the Civic harness to fit the H22.. do some searching in this section and you'll find a post by me that outlines what you have to do with the civic harness..
Good Luck.
Good Luck.
averyvm
01-12-2007 12:01 AM
bomber
09-03-2004 04:45 PM
