Vtec spool solenoid code in gsr'd eg
Old Aug 1, 2003 | 05:59 PM
dreweg's Avatar
Default Vtec spool solenoid code in gsr'd eg
We recently swapped a 98 gsr motor with a b16 head (w/gsr cams & throttle body) into my 92 cx hatch. Everythng is fine but everytime I hit vtec the check engine light comes on....it's code 21 which is vtec spool solenoid i believe. Well we're still using the obd1 p-72 and we looked in the haynes manual and it says " code 21 vtec spool solenoid (gsr only) So im guessing since i put the b16 head on it it's just not there...and the ECU isnt getting any signal. Anyway is this something I should fix or is it alright. Once the car is cut off and i restart the CEL isnt on until i hit v-tec...i could drive all day and shift at like 4 grand and the CEL never come on. Anyway we also changed vtec solenoid to make sure it wasnt that. Thanks for any help.
Drew
Old Aug 1, 2003 | 08:07 PM
VTECVillain's Avatar
Default Re: Vtec spool solenoid code in gsr'd eg (dreweg)
Did you use a VTEC engine harness or the stock CX engine harness? I would say the problem is in the wiring but without seeing it I can only assume, and you know what they say when you ASSume.....
Old Aug 2, 2003 | 08:53 AM
dreweg's Avatar
Default Re: Vtec spool solenoid code in gsr'd eg (VTECVillain)
I used an obd1 gsr harness. I have the vtec grounded and ran to a4 in the ECU....the vtec oil thing is at d6. Is ths correct? I checked all connections and they are good. It seems vtec is working though....I only have an intake (not cold air) and a POS ractive exhaust and it seems to pull decent on high end. In the manual it said gsr only....but im not the smartest guy when it comes to these things.
Gsrsi
Nov 18, 2011 05:15 AM
santacruzccs
12
Feb 6, 2009 09:37 AM
AdamQ3B85
Sep 9, 2005 04:10 AM
dreweg
Aug 2, 2003 08:55 AM
chet
Jul 17, 2003 11:57 PM
