b18c in 1990 teg, what do i do about MAP, IAB and EVAP
These all have vacuum lines coming to them on my old motor and the b18c has wires. what do i do. also, where is the IAB, im not sure. thanks !
Re: b18c in 1990 teg, what do i do about MAP, IAB and EVAP (b18c3)
The IAB is located directly under and attached to the intake manifold. It's a black plastic canister and the sensor plug faces the driver's side. The MAP sensor is on your firewall and you will need to run the hose from it to the top of the throttle body on the B18C or use the MAP on the B18C throttle body and make your MAP plug reach it. The EVAP I'm not too sure about unless I'm looking directly at the setup.
