just swapped LSD H22A trans...HELP!!
New User
just swapped LSD H22A trans...shuddering problem...HELP!
I just swapped my M2A4 for a M2B4 LSD trans, now when I drive the car when accelerating or decelerating, i get a shudder from drivetrain.
It almost feels like I have a bad axle, but It drove fine with the old tranny.
Could it be a bad LSD??
Heres my setup:
EG hatch
90-93 Integra axles
90 Accord int shaft
Hasport mount kit
Modified by CanuckCRX at 7:44 PM 8/3/2003
Modified by CanuckCRX at 7:54 PM 8/3/2003
Heres my setup:
EG hatch
90-93 Integra axles
90 Accord int shaft
Hasport mount kit
Re: just swapped LSD H22A trans...shuddering problem...HELP! (CanuckCRX)
The H22A transmission with LSD is wider at the differential and is causing your passenger side axle to bind because it is too compressed. Call someone like Raxles, Driveshaft shop or Hasport to get the correct size axle.
brian g
brian g
New User
Re: just swapped LSD H22A trans...shuddering problem...HELP! (brian g)
Can I make one?? Like maybe an 86-89 shaft with a 90-93 inner?? Like the CRX custom B16A axle?? You know what I mean...something with a shorter axle shaft itself...
I also have JDM H22A axles as well, can I use these for parts?
If the diffs are different widths, why doesn't anyone mention this before hand??!
How about an Integra Type R axle...
Modified by CanuckCRX at 1:55 AM 8/4/2003
Modified by CanuckCRX at 1:56 AM 8/4/2003
New User
Re: just swapped LSD H22A trans...shuddering problem...HELP! (hondaeg5)
I have a place where I buy all my engines from..JK Japanese Used Auto Parts..it's in Toronto..If you want the number pm me...
I have the same problem with my hybrid 4th gen I have shuddering problems. And as far as the bucking it does leave off regular I sometimes have to give it a little throttle before I pull off cause it shudders . And it makes noises like its fighting with itself what can it be Its a h22a with a quaife limitedslip differential and it has accord axles on it. Could one of em be busted that would cause it to do this?
I just got my H22 EG swap done and I have the LSD tranny. My axles from driveshaft shop were the wrong length (both) so they sent me a new set. There is still a slight vibration, but its not bad really.
New User
Re: just swapped LSD H22A trans...shuddering problem...HELP! (SleeprCivic)
I'm going to try an 86-89 Integra axle shaft with the JDM Prelude inner joint...I will keep you posted on the results.
Brian G---> Thanks for the help,thats why I buy your mounts...
I have a JDM H22A LSD trans. for sale. If anyone is interested, e-mail me @ BlazingSIRT@aol.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanuckCRX »</TD></TR><TR><TD CLASS="quote">I just swapped my M2A4 for a M2B4 LSD trans, now when I drive the car when accelerating or decelerating, i get a shudder from drivetrain.
Heres my setup:
EG hatch
90-93 Integra axles
90 Accord int shaft
Hasport mount kit
This is why I'm pretty sure my axles are too long....I've got the exact same symptons.
Does the car kind of jerk and rock back and forth like something is binding in the drivetrain when you try to reverse?
Heres my setup:
EG hatch
90-93 Integra axles
90 Accord int shaft
Hasport mount kit
New User
Re: just swapped LSD H22A trans...shuddering problem...HELP! (Jonathan_EH)
Well, with the 86-89 Integra inner and the Prelude inner joint, all is well here.
Take your DSS axles and Ebay em.
Lockner13
02-29-2012 06:57 PM
cpforyou
06-12-2004 03:45 PM
