clear this up real quick (HCP mounts)
Old Jul 30, 2003 | 01:30 AM
F120man's Avatar
New User
Default clear this up real quick (HCP mounts)
my hcp mounts on my eg dont "look fitted." the mounts fit real tight onto the eg mounts, and i had some trouble trying to fit everything in, so it came to the point where you just wanna get that **** in. well i did, but the polyurethane bushings on the ends are kinda bent on the two front mounts. the side bushings on the front transmission mount is kinda gapped and the driver side mount's bushing looks smushed against the mount. id just wanna know if this is ok, cause i dont wanna go thru the install again. but im really anticipating for the car to be done, ill have pictures up when im done.
Old Jul 30, 2003 | 02:40 AM
Turbogixxer's Avatar
Default Re: clear this up real quick (F120man)
Do you know if your car has frame damage? (aka bent frame)
Modified by turbogixxer at 7:03 AM 7/30/2003
Old Jul 30, 2003 | 09:53 AM
F120man's Avatar
New User
Default Re: clear this up real quick (turbogixxer)
yes, its a savalged title car, and there was major front end damage.
Old Jul 30, 2003 | 10:23 AM
That is most likely you problem. it will take some money to fix it right.
Old Jul 31, 2003 | 03:08 PM
fastwanabe's Avatar
when it comes to aftermarket mounts the frame needs to be intact prior to installation or esle nothing will line up.
Old Aug 1, 2003 | 09:52 AM
F120man's Avatar
New User
Default Re: clear this up real quick (fastwanabe)
the frame is intact, its just recomved from a fron end collision. the car looks fine now, just that when you look at the motor while its in the engine bay. the motor looks kinda tilted to one side, and when you look at the mounts, its kinda smushed and looks forced into the mount.
hybrid2007
Jun 25, 2007 11:00 AM
CA6VTEC
Oct 18, 2005 09:33 PM
Turbocivic94
May 17, 2005 09:02 PM
MysteryWagon
Jan 5, 2002 05:19 PM
