Plans changed....now 00 b16a in 92 cx....help....
I have a 2000 civic Si thats getting a new engine soon. I also have a 92 cx that needs an engine now. I am going to take the si engine, trans, ecu, wiring, shift linkage and axles and put them in the cx, is there anything else I will need?
Re: Plans changed....now 00 b16a in 92 cx....help.... (80884)
The wiring harness won't transfer over. You'll need to reuse the stock CX engine harness and wire up the appropriate sensors. Also it would be much easier to get an OBDI chipped P28 or JDM P30 to run the motor.
Re: Plans changed....now 00 b16a in 92 cx....help.... (VTECVillain)
The wiring is no problem. I can't use the si ecu? is this due to the odb2 stuff? Would I just have to ad an o2 sensor?
Also what mounts do i need to use?
Is there anything else I should know, I'm gonna try to do this tomorrow.
vwible
08-10-2005 03:38 PM
LegoZ81
10-15-2002 06:56 PM
