Wiring in Knock Sensor?!
Old Jul 27, 2003 | 08:40 PM
95hbMatt's Avatar
Default Wiring in Knock Sensor?!
I have a 96 LS motor in my 95 DX civic hatch, using the OBD2 wiring harness mated to my civic chassis harness plugged into a P75 OBD1 LS ECU.
I was surfing around and came across a post saying that everything is plug and play(which I knew already) but the only thing that needs to be wired is the knock sensor. Is this true?? Any insight on this? Also i've had this swap in over a month now and seems to be running fine....
Old Jul 27, 2003 | 08:45 PM
95hbMatt's Avatar
Default Re: Wiring in Knock Sensor?! (95hbMatt)
Also for clarification: The P75 doesn't look for a knock sensor correct?? So I should be fine right?
Old Jul 27, 2003 | 09:04 PM
Turbogixxer's Avatar
no, it does not. Your Dx already has a four wire o2. it will be plug and play.
Old Jul 27, 2003 | 10:54 PM
simple4012's Avatar
New User
Default Re: Wiring in Knock Sensor?! (turbogixxer)
your dist. plugs will need to be changed as do your injectors clips. nothing else comes to mind
Old Jul 28, 2003 | 06:31 AM
95hbMatt's Avatar
Default Re: Wiring in Knock Sensor?! (simple4012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple4012 &raquo;</TD></TR><TR><TD CLASS="quote">your dist. plugs will need to be changed as do your injectors clips. nothing else comes to mind</TD></TR></TABLE>
No they don't....i'm using the Integra engine harness that came with the motor. LIke stated above i'm using an obd2 engine harness and it's plug and play to my civic chassis harness(obd1).
Old Jul 28, 2003 | 06:38 AM
95hbMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">no, it does not. Your Dx already has a four wire o2. it will be plug and play. </TD></TR></TABLE>
Ok cool, that's what I figured. Yeah I have my O2 plugged in and i'm not running any codes or anything, I just came across a thread about it and thought i'd ask.
Old Jul 28, 2003 | 07:36 AM
He is correct. As long as he is running the OBD 1 P75, he will be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hbMatt &raquo;</TD></TR><TR><TD CLASS="quote">Ok cool, that's what I figured. Yeah I have my O2 plugged in and i'm not running any codes or anything, I just came across a thread about it and thought i'd ask.</TD></TR></TABLE>
yeah, you should be cool. only vtec motors and 99-00 b20z/b came with a knock sensor. Good job with the swap and go drive that thing!
bustah49
May 11, 2007 07:57 AM
agy2k2
Aug 8, 2006 04:47 AM
ahemming06
Mar 30, 2006 03:31 PM
WOODman
Jul 30, 2005 02:31 PM
EGTHU6
Jul 28, 2004 01:50 AM
