purge on swap
purge on swap
hey guy i need to found out about my purge unit... i just install a 92 JDM b16a and its doesnt have a plug in the mainifild for my purge...but it has it own purge unit on the back of the manifold(close to the firewall) plus do i have to use my old engine harness? are should i change the harness to a USDM? need help really bad..
Re: purge on swap (RiceNmotioN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceNmotioN »</TD></TR><TR><TD CLASS="quote">hey guy i need to found out about my purge unit... i just install a 92 JDM b16a and its doesnt have a plug in the mainifild for my purge...but it has it own purge unit on the back of the manifold(close to the firewall) plus do i have to use my old engine harness? are should i change the harness to a USDM? need help really bad..</TD></TR></TABLE>
You need to reuse your stock harness because the JDM B16 harness is designed for a RHD car cand won't work. They can be salvaged for plugs but that's about it. The EVAP purge is probably mounted on your firewall so by using the stock harness it will reach and plug in.
highroller54
02-13-2007 08:29 PM
GMR*Spork
06-03-2006 11:47 PM
wizzards581
10-21-2003 09:55 AM
